wats the difference between zonealarm and zonealarm pro?
mOrphine
638
can someone enlighten me here pls?
or are there some other firewall programs u can recommend?
thanx <G>
jaywallen
1,227
ZoneAlarm freeware is sufficient for standalone systems that use dial-up or cable/DSL to go online. ZoneAlarm Pro provides flexibility in setup that is needed for some (most?) sytems that are used on networks.
Both work very well and are easy to set up and use. The ZoneLabs site has online info that will help you determine which you need, and will help you understand the setup procedures for use in special circumstances.
Regards,
Jim
FOBSIDE
2,178
is there a way in zone alarm to let it know what programs to access the internet and act as server without first having the program try to access the internet first?
