Ok,
Here is my setup:
I'm going to be using a Lian Li PC-75B, it's really large, especially near the top. I'm looking at a Modstream or Powerstream to power it, either 520W or 600W, any input on a PSU that is going to be able to handle all that overclocked and a pump?
Athlon 64 4000+
DFI Lanparty nF4 Ultra-D (On 4V for DRAM)
ASUS X850 XT
2x512 OCZ PC4000 EL Dual Chan VX Gold
1xWD Raptor 74Gb SATA
1xSeagate 200Gb SATA
NEC ND-3520A
Audigy 2 ZS
Now, I definitely plan on overclocking it as high as I can with it being stable, and I have a feeling that is going to be pretty high.
With that said, here is my current idea of a setup:
Waterblock: Either TDX 64 with copper top, 1/2" fittings or a Swiftech MCW6002-64 with 1/2" fittings. Can I get some outside opinions from you guys on which you think is the best? If the TDX, are the accelerator nozzles recommended?
Chipset: Danger Den MAZE4 Chipset Block with 1/2" fittings.
GPU: Danger Den Acetal MAZE4 with 1/2" fittings.
Pump: Danger Den DD12V-D4 with 1/2" fittings
Radiator: Now, I care about looks, but I care about performance more so I am looking at the heater core here:
http://www.dangerdenstore.com/product.php?productid=48&cat=14&page=1
I would put it would a shroud with 2 120mm (85CFM) Panaflos in push/pull config if there's room, if not, then just 2 120mm Panaflows on it. That or the Black Ice Xtreme III looks like a waste, but you guys tell me. I'd have 3 of the same Panaflos on it. I am looking to mount this at the top of the case, but if needed, the bottom. Definitely need some good input on this situation.
Reservoir: Danger Den RESHDPE or Danger Den Single or Dual 5 1/4" bay one, which would be the best?
Misc: 1/2" Tygon with clamps, AS5, etc
Also, Fluid XP+ because I like the peace of mind it'd give me in the tradeoff for 1 or 2C.
Thanks very much, any and all input is much appreciated. If you completely disagree with any of my choices, let me know what you think.
Here is my setup:
Athlon 64 4000+
ASUS X850 XT
NEC ND-3520A
Audigy 2 ZS
