Has anyone done a Watercooling setup where they simply stuck the radiator block in an aquarium? Like a ten gallon tank. Don't even have a fan, just a pump.
I've never heard of it done ... but does not mean it hasn't. The heat transfer (from the radiator) would be greatly improved over air but what are you going to do once the water in the aquarium heats up itself? Air is less dense but there is plenty of it all around us. A 10 gallon tank seems huge until you consider that you are limited to only 10 gallons. The water in the tank will eventually heat up and reduce the cooling efficiency of the waterblock ...
Not in a fish tank but passive and at least is the GIGANT range from Aqua Computer, it will hold the reservoir pump and controller. Pick your size and hose your rig up.
http://shop.aquacomputer.de/index.php?cPath=7_31_2026&XTCsid=pgt5c6d97igce60e4he1d260koikuslv
Temporarily, yes it will work great. Long term? Nope. Not going to happen.
Add up everything you have covered with a block, wattage-wise. Bet it's over 200W (assuming full load).
Put a 200W heater in that 10 gal aquarium and watch how fast that water heats up way past ambient.
If you have a spare chiller (again of sufficient capacity!) this will work.
In rural areas where multiple wells are common one could pull water from one well, run it through a titanium water to water exchanger and return the water to the second well. The computer's circuit water would then be circulated through the other side of the exchanger. (closed circuit)
This way you could have sub ambient coolant levels but in humid climates you would need a mixing valve to prevent surfaces from approaching ambient dewpoint which is never a good idea around electronics.![]()
Well, I game rarely and at that I only game for a 1-2 hours at a time. Also, this would be the cpu only and most cpu 's are 65 watt nowadays, right? Even at full blast all the time 65 watts would actually be a little underpowered. Though I do agree with that including the video card in there would heat things up considerably...it is also considerably harder to install a water cooling block on a video card and that procedure requires that you freeze the video card and then pry off the cooler...
So I think it could be done.
