First I would recommend you check out www.ocforums.com for some info on water cooling (and pumps). I've been doing some research since I plan to also water cool my next PC. Since I want to make this a quiet PC (as much as possible) I'm going with an AquaXtreme 50Z-DC12 Pump. I prefer to power the pump from the PC power and not need external power.
Originally posted by: racolvin
Would like to look at a selection of pumps for a WC setup. Anyone know a good website that sells a selection of pumps? I'm a US based customer 🙂
Any comments on that one? The Innovatek guys seem to have a good reputation, and this particular pump is powered from the PC power supply, which I prefer.
Remember thats really Eheim's pump and they make very nice solid pumps. Keep in mind that the HPPS 12 volt is converted from AC, and Eheims do tend to be a bit noisy as compared to some of the other highly rated pumps (50Z, Laing DDC and D4 and Danger Den's 12v).
Hi I ran a hydor L40 for a few years it was a verry good pump as for the L45
should be good also. I was going to buy the L45 but i bought the Eheim's 1260.
and is very quiet and im water cooling 2 pcs now. 😀
