Watercooling(Kits?) 3930k Help!
sod16
The basic story is,
I really don't want to buy those h100's or a D14 as D14's are to big and the h100's I've heard are rubbish.
I need overclocking room and I've seen kits from:
EK
XSPC
I don't want to upgrade, I just want something that will let me overclock a lot and not produce too much noise/heat while still being reliable.
I also have a budget of around £130.
Can anyone recommend something for me? I get so confused, you get really expensive 240 kits, and cheap 360 kits, or will a 120 do fine?
Plus I would love this to all fit into one case.
I'm sorry for the long winded post but I really have no idea.
Grooveriding
9,147
1,330
You can't get anything decent for that price in terms of proper water cooling.
Either bite the bullet and deal with a huge cooler, NH-D14, or get the H100 and deal with the QC issues it has.
T_Yamamoto
15,007
795
if you have 1000(USD), you can water cool your pc, but im pretty sure 130 euros is not close to 1000 usd :p
sod16
Ok, how much to watercool JUST the 3930k at 4.8Ghz reliably and safely + Looks. No upgrade room either.
If possible list some parts?
aigomorla
21,087
3,598
The basic story is,
stay on air cooling.
Radiator = 75% of what your going to be able to do on water.. regardless of setup.
If you saying a 120x2 radiator is too small, then no.. u wont like the customs at all, because i start pushing at 120x2 for radiators even for cpu only loop.
sod16
You saying a RS240 will do to OC a 3930k and still be 20db?
