Originally posted by: OILFIELDTRASH
I was thinking of building a loop for my cpu. I have a cooler master atcs 840 case. There is a place on the top for 360 rad but I read its best to have res above rad. This would be impossible for me. Also how do I bleed a loop with res. Should I go with just a T. Whats some good brands. Also would like my watercooling loop to be able to go to core i7 when ready. Would this just require different block? What do you think of the pre built kits?
You do not need to have the res above the rad and in most cases (like yours), this simply is not practical.
As Aigo stated in
this stickie it is much quicker to bleed a loop with a res than it is just using a T-line. Ideally, you can use both; the benefits of using the res is that it is easy to top up the loop with water and it is quicker to bleed and the T-line can be used to drain the system. I would also recommend having a separate fillport (i.e. a fillport in the top of the case with a tube leading down into the res) because this means that the place where you fill the loop is remote to the inside of the case containing all your expensive electronics.
The Bleeding Process:
When you first fill the loop you must completely fill the res up to the brim, because the pump cannot be run 'dry'. Since the rest of the loop does not have any water in it to begin with, the pump with quickly reduce the water level in the res as the rest of the loop/components fill, so you have to continually top the res up. The pump will also sound noisy to begin with. As the loop completely fills with water with you topping it up, the air will be forced (with some persuation by gently rocking the case to-and-fro to get the air out of the nooks and crannies) around to the res and out through the fillport, which must be left open during the bleeding process. As the system bleeds (i.e. all the air comes out) the pump will get quieter and quieter. You will know when all the air is out because the pump will stop sounding like a bag of hammers.
A lot of water blocks come with universal mounting plates, which are suitable for several socket sizes (i.e. AM2/3, LGA775 and LGA1366). If the water block doesn't come with a universal LGA775 / LGA1366 mounting plate, then you can usually buy the LGA1366 mounting plate separately.
Before we go into what parts we would recommend, what is your budget and what are you wanting to water cool (i.e. what CPU is it) and why?
Edit: Billb2 beat me to it
