Watercoolers, at what rate does your loop evaporate water ?
Grooveriding
9,147
1,330
Hola,
I use a tube res in my loop and have been noticing the rate at which my system loses water. I keep my res topped out and through every three week span or so I see a slow accumulation of tiny bubbles at the top leading to about a 1/3 of a cm of water loss by the three week mark.
I've been wondering if I have a slow leak somewhere, but have checked and checked again and cannot find any leaks in my hose, rads, pump or fittings.
Does this sound like a normal amount of water loss. I understand there is some loss of moisture through your hose and other factors at play.
Thanks.
BrightCandle
4,762
In a 5 1/4 bay res I loose about 4-5mm a year. Bare in mind my loop is sealed completely, and presumably so is yours so there should be very minimal loss. You have a slow leak.
dma0991
2,723
Filled my single bay reservoir to the brim since I've built the rig when IB came out. Probably about 350ml when I first filled it, have yet to go below the 300ml mark. A rough guess would be 325ml.
Kenmitch
8,505
2,250
Very, very little. I check it once in a while but when I look it's still full. I only gotta add water when I mess around with a MB swap for the most part. I just swing my loop out of the way which twists one hose on a rad and makes it drip a little bit. I just use the XSPC mini res mounted about 2 inches above my pump. It's next to the side of my case so I just look thru the holes to see it. I guess maybe it has dropped about a 1/32" from the last time I messed with it a couple of months ago.
PCTC2
3,892
33
I don't think you have a leak at all. Some of my systems would lose 1/3 cm every month. I would top off every 6 months.
But if you're wary, here's what happened to me.
Back when I used my Swiftech Microres, I noticed a lot of drop off. Over a period of 6 months, I might've lost 1/3 of the reservoir.
This was not because of a slow leak. It was because I didn't screw the top cap of the reservoir on completely. The constant motion of the water (24/7 machine) at higher than room temperature levels would cause evaporation, which would leak through my top cap, lowering my water levels quite quickly.
TLDR: Check your fill-ports and caps to see if they're sealed completely.
Schmide
5,745
1,036
They don't, same loops running for 2.5 years.
I'm really thinking of going for some record. I've upgraded from a q9550 to a 2500k without draining.
