Water Stuck In Ear
Spooner
12,025
i think i stood the wrong way in the shower this morning and i've had water caught in my ear all day and i've had to deal with that annoying clogged ear feeling :|
any home remedies to help with this?
Canai
8,016
Umm qtip or hairdryer or roll up a piece of toilet paper (a little one) and kinda fish around until it absorbs some of the water. Otherwise just sleep with that side down or sit next to a fan for a while. I used to get water stuck in my ears when I went swimming, turned out there was a bunch of wax built up.
Ear candles ftw.
Staples
4,953
119
Just position your ear horizontal to the ground. The water will come out in 30 seconds or less.
bersl2
1,617
I have to jump up and down to make that work. People look at me like I'm strange (well I am, but that's beside the point), but whatever works...
JasonE4
1,363
Dump peroxide solution in there and let it sit for a couple minutes then dump it out. Repeat if necessary.
Kalvin00
12,705
here's a solution that works for me everytime
turn on water faucet to warm. run your finger in it. turn offending ear to the sky. take your finger and place in your ear so a few drips go in. wait a couple seconds, tip head other way. repeat as necessary.
akshatp
8,349
Ahhhh that feeling you get when it finally leaves the ear canal... It has to be the 2nd best felling in the world after.... well, u know...
On a more serious note, be careful when sticking a Q-tip or anything else in your ear!!
akshatp
8,349
Won't this create more water in the ear canal? Please elaborate as to how this helps?
Spooner
12,025
right? wouldn't it have fixed in the shower then? my shower's are pretty hot
Kalvin00
12,705
has worked for me everytime i get water stuck in my ear after swimming or whatever
give it a try
deadlyapp
6,671
744
give it a try
siphon effect.
I sometimes actually plunger my ear if i'm in the pool. take my hand with my ear in the water and force it against my ear then bring my ear out of the water.. Works 9 times out of 10.
akshatp
8,349
give it a try
siphon effect.
So you are basically forcing more water into your ear??? And then when it all falls out it takes the original water out with it?
I am so confused
SViper
828
Alcohol usually works (not drinking alcohol) :). People with "swimmers ear" suffer from ear infections from water staying in the ear. How do they fix it? They put an alcohol solution in there ear. My brother suffers from this frequently. Instead of buying the "swimmer's ear" stuff at the store so many times, we just get some rubbing alcohol. It does the same thing.
BoomerD
66,355
14,768
I've had the "pleasure" of swimmers ear for over 20 years...not fun.
Use either rubbing alcohol, or one of the swimmers ear products sold in the drug store. All are alcohol based, with a variety of other ingredients to help.
You can make your own, using a 50/50 mix of alcohol and white vinegar...
compnovice
3,192
give it a try
siphon effect.
I am so confused
Works for me everytime... I guess its just the surface tension vs gravity effect. Water is stuck in the ear because it forms drops due to surface tension. However as more water is added the drops break and all water flows out... I might be wrong on the theory, but it works in practice...
imported_Tick
4,682
give it a try
siphon effect.
I am so confused
As far as I know, water only get's stuck in your ear because of a balance between water volume/ear canal size/surface tension/gravity. So if you mess with this balance, it should fix the problem. Also, anything that affects waters surface tension should help, so try a drop of liquid soap in your ear canal.
Mill
28,558
There are alcohol-based products that you should be able to buy at any pharmacy or grocery store. I encounter this occasionally, and I keep a bottle around to dry my ear out.
I don't know about using rubbing alcohol, but I'd do more research before going that route.
redgtxdi
5,464
8
EAR LAVAGE
You can do this with a bulb syringe in the shower............(Yes, you're forcing more water into your ear to expel the water that's currently stuck in there)...........or you can go to a doctor and they will do it with a much more powerful lavage device.
Problem is more likely that you have a 'plug' of wax in your ear and the water has made its way 'behind' this plug. A good ear lavage is the only thing that will clear it out. It will be disgusting and the site of it will probably make you gag. However, once cleared out you will hear like you've never heard before........seriously!
If you do it with a bulb syringe in the shower just be sure to use luke-warm water. Cup some water with your hand next to your chest and syphon the water into the bulb and then squirt it into your ear canal. Too hot or too cold could make you a little dizzy, but nothing to worry about. It may take several attempts to clear the wax plug out of your ear this way. A doctor can do it more efficiently but of course you have to...........well.........go to the doctor for that.
No bull.
thepd7
9,423
50/50 alcohol vinegar for the win from a 7 year lifeguard/wsi/lgi.
