Relates to my hot water heater upgrades actually.
Got my new elements in, heater works great. However, after filling the tank back up with 50 gallons, I realized that my drain valve at the bottom is leaking. Nothing major but probably a cup of water every 8 hours. Enough that it needs to be replaced.
Question: If I cut off the main water-in valve to the water heater, leave the pressure release valve closed and keep all faucets in house closed, is it possible to remove the bottom drain valve and put in a new one without draining the tank? I understand that some water will still trickle out. But wouldn't the lack of air in the tank create somewhat of a vacuum inside the tank, thus preventing water from gushing out the drain valve?
Just curious if it's possible to replace that drain valve without draining the entire water heater again. Looking forward to the simplistic answer but also to MS Dawn's response as well. 😀
