Water in Bottles
cbrunny
6,791
406
How long can water sit in a typical plastic water bottle (e.g.
before it is no longer "safe" or "good" or whatever to drink? Assume the bottle was fully sterilized before hand. Is there a limit?
Trying to solve a problem that none of you actually would ever care about. Not in a mean way, just the truth.
highland145
43,973
6,340
fully sterilized
forever-ish. Adding the chlorinated water from the city.
I've left them the fridge for a month or more.
If there's brown crap growing in it, I'd probably not drink it unless I was on naked and afraid.
Red Storm
14,233
234
If it's not at extreme temperatures, probably quite a long time. I've read that extreme hot or cold temperatures can mess with the water.
deadlyapp
6,677
751
Are you worried about organisms and such growing in it or about something from the plastic leaching into it?
Either answer is probably an unbelievably long time. There are plenty of people who try water from gallon jugs that they had in an emergency kits for many years with no ill effects (other than possibly the water tastes stale).
shortylickens
80,287
17,082
theres no such thing as typical plastic.
The reason water has an expiration date is because the cheap plastic used in retail water breaks down relatively fast and dumps toxins into the water, making it unhealthy.
You need to specify exactly which kind of plastic you are using in order to know how long water will last in it.
Fun Fact: Most emergency water is kept in aluminum packets because it doesnt break down quickly.
Reactions: angminas
cbrunny
6,791
406
mostly the leaching from the plastic, but also the bacteria - just less so.
Ruptga
10,246
207
So, put it in aluminum so you don't need to worry about leaching, then when you want a drink cook it with a microwave to kill any bacteria present.
MrSquished
26,270
24,548
or glass. It doesn't inpart any taste to the liquid. I have a pricey but reusable water bottle that is glass wrapped in a protective rubber. Though I can imagine metal being lighter.
35,133
I keep water in pop bottles in the car. Temps hit 120-130 easy, much higher in summer. Water tastes okay for a couple months. Tastes nasty assy after that.
Mar 11, 2004
23,444
5,852
Yes, there absolutely is a typical type of plastic used for a lot of different products. Pretty sure they have to specify the type it is now too so you should be able to find that out. For the water bottles the OP is talking about there are several plastics that would be expected (although they have gotten more variety, especially after people started freaking out about certain types).
That is bullshit. Average plastic water bottle (as in if you buy a bottle of water) is PET, and that doesn't leech (let alone break down in any meaningful way) unless put in heat (and even then they have versions that are heat resistant) for extended periods of time.
Yes, you do need to know the type to know how it will fare, but you are grossly exaggerating this. Not saying it isn't a problem at all, and yes some are absolutely worse (BPA for instance), but it's not at the levels you make it sound like, and typically requires pretty excessive heat or certain conditions.
The aluminum pouches are for various reasons, but they are for emergency use and so need to hold up to a wide variety of environments. I'm guessing they probably have other benefits (i.e. I'd imagine they'd hold up to heat, so you could use them to gather water from the environment and boil it in the pouch to kill bacteria).
