Baked
Due to work, I'm usually not at home. The other day, I turned on the hot water and waited... and waited... and waited... and no hot water came out. Just lukewarm water came out. I know when the plumber reinstalled the water heater, he changed a couple of copper connector tubes that's used to connect the water heater to the wall pipes to aluminum connector tubes, saying that it's more flexible. I didn't think much about it at the time, but now that I think about it, why do you need tubes connected to a stationary object to be flexible? I know copper is used in plumbing 'cause it has the best heat retention/cost ratio. The damn plumber probably just stole my copper pipes so he can charge another client more money for the "change order."
But could this simple switch in connector tubes be the cause of me not getting hot water? Or is there some kind of switch or knob on the water heater that's affecting the temperature of the water?
Ps. This is an electric water heat.
