illusion88
So my water heater is overfilling. There is a pressure release valve that leaks water, every now and then. Sometimes it comes out at alarming rates, almost as much as if I opened the valve at full blast. It also makes a horrible screeching noise.
When you turn on water around the hosue, this noise goes away. IT will also stop leaking. If you turn off the cold water input, the screeching noise goes away, so does the leak.
What the hell is wrong with my water pressure or water heater?
