Hi All,
The water heater was dripping a bit from the drain valve and called Rheem, was told to replace it to a standard brass valve. During the process of replacing it, I discovered it was the plastic part attached to it that was damaged and I would like to just replace it instead of the whole thing.
Does anyone know what this part is called or where I can find one? Rheem told me I cannot purchase it separately...
