Originally posted by: shortylickens
If its for the home I would recommend a Brita. It did well enough for me over the years. You can get them in pitcher assemblies and other types.
i was hoping for something a little better than the pitcher type. i was thinking UV rays even.
even if its a few hundred $$ thats fine.
You can even distill and purify Vodka in Britas. Invest in one.
One of the cheapest and easyest solution is 2 or 3 stage sediment/cabon filter that is great to have good water tasting (20-30 micron/5-.01 micron, most application .2 to .1 micron carbon is more than adequate and serve as a water softener to take out chlorine).Originally posted by: rhino56
this is stationary for my home. i want to be able to take any water within reason, and make it like dasani
got a link to any specific model?
so where to buy one online?Originally posted by: JinLien
One of the cheapest and easyest solution is 2 or 3 stage sediment/cabon filter that is great to have good water tasting is (20-30 micron/5-.01 micron, most application .2 to .1 micron carbon is more than adequate and serve as a water softener to take out chlorine).Originally posted by: rhino56
The best for home use is RO (reverse osmosis) and combine with carbon filter you will have water that taste better than bottle water (no plastic smell/taste or chlorine).
[add]
above solutions are great for under sink or entire house filtration application.
UV is (the relatively expensive bulb burn out and constantly needed to be on) more expensive than the previous 2 method and require carbon filter to soften & take out chlorine taste, and it may require sediment filter as well.Originally posted by: rhino56
Best is to find out from the local dealer to see what you need, because it depends on your local city/well water.Originally posted by: rhino56
[add]
i would prefer overkill and the 3 stage. they dont sell them online at all?Originally posted by: JinLien
[add]
2 stage is good if the local water doesn't have too much sediment, and 3 stage maybe needed if city or well water is poor.
Find a system that have the lowest filter cost/gallon of water, because the filter will cost more in the long run when compare to the rest of the equipment.Originally posted by: rhino56
[add]
yeah i can understand that. i guess im gonna have to try google for water filters to find a place to buy.Originally posted by: JinLien
[add]
Originally posted by: scott
Your profile says you're in Arkansas.
Why don't you call:
(A)
U.S. Filter
14420 Union St.
Little Rock, AR 72206
Phone: 501-897-5764
(B)
Camfil Farr, Inc.
Farr Co.
3505 S. Airport Rd.
Jonesboro, AR 72401
Phone: 870-933-8048, 800-479-6801 (toll free)
(C)
(In addition to the online REI purchase site I linked for you in a previous post above.)
(D)
Search resource for you here, search term "drinking water filter"
