water cooling ???
BigMoe
476
So what do you need exactly for water cooling 1. a pump 2. a Radiator 3. reservoir
4. water block 5.tubing any thing more???
BeauJangles
13,941
Some sort of water whetter to prevent things growing inside the tubing, and to prevent corrosion.
BigMoe
476
thanks does one need a pelter? are they much harder to install than a standerd air heat sink? do the pumps last as long as the fans?
s2kpacifist
108
If you're going to get a peltier you better be prepared to deal with the condensation generated from the cold side of the TEC. So, you'll also need some dielectric grease and foam fitter-thingys that fit around the cpu.
However, if you're just going to overclock it a little, or not even....TECs aren't necessary at all.
