- Aug 18, 2000
- 492
- 0
- 71
I recently just built my first system, last week actually. And i've been doing alot of benchmarking and other tests, like heat build up. I have a duron 800 unlocked with a super orb, an msi k7t pro2a, hercules mx, and a black hydraulic case. I have an 80mm sunon fan in front and a 60 in the back below the 300w psu. I have idle temps at 38 and stress temps at 45 with my duron at 950 1.8v.
I know this is well within the accepted range, but my computer is somewhat loud. If i change to a water cooled solution i assume that there will be significantly much less noise. If so how much? Also what if any kind of maintenance is needed on it? What would i expect to be spending if i switched? And could anyone recommend any sites so i could go look for even more information.
Thanks
Thanks
