water cooling
Dec 11, 2011
50
if i watercool my processor it won`t be dusty, right?
do i need a good airflow if i use a h80? I think i can put the fan outside the case...
do i need other coolers for ram, mobo, hdd ?
i want a cool and silent pc (and no dust) ...
Thanks
T_Yamamoto
15,007
795
its impossible for it to have no dust
just add some filters and add some quiet fans and call it a day
itll save you money and will also be quiet
Dec 11, 2011
50
can you recomand some quiet coolers?(2500k)
do i need coolers for ram??? (ripjaws 4x4 no cooler or i should buy 4x4 corsair with vengeance cooler?)
T_Yamamoto
15,007
795
Ram does not need coolers or heatsinks.
make sure the ram is rated at 1.5v, because sandybridge was made for 1.5v ram
a quiet cooler would be as follows:
*NOTE: some are expensive, but they work amazingly
Noctua (known for highend fans)
Scythe (also known for amazing fans)
CoolerMaster (we recommend this one alot, and you can add an extra fan for pushpull)
aigomorla
21,134
3,673
Thanks
LULZ...
90% of my computer is watercooled...
This is the DUST.
radiators need AIR... AIR carries dust...
You need to be a perfect sealed room for no dust... or u need to get good filters to catch the dust.... but those collect dust regardless.
T_Yamamoto
15,007
795
LULZ...
This is the DUST.
clean out that dust!
