Water Cooling
Paintedeyes
83
Hello, I got a water cooler a few months ago "Evercool WC-202" I got it because i thought my system was getting pretty hot, asus booster read my cpu getting up to over 60C and i had a very expensive heat sink wit some heat pips on it. my first water cooler didn't work and i had to send it back and i stalled the new one last week. It is awful, it's running soo hott. My asus booster says it has reached around 80c and that cut the speed down in half since i'm running a pentium. Although the front panel says it's 47.2, even though i believe that is still hot for a water cooler. They sent me a new product cause icompalined big time to them. idk if i should even waste time putting it in if i will get the same result
Nov 23, 2006
84
it is possable the reading are wrong, if the front panel says its 47.2 then the processor will probaly be about 50-60(depending on where you put the sensor. download some software to read the temps in your pc. i cant remember any but maybe someone else can recommend something.
Paintedeyes
83
well the bios temp was the same as my ai booster temp getting up to the 80's which is outragous.
that first link tells me it was around 46 it hink under load? mine is hotter than that when it's not doing anything and my comp has been a bit slower since after putting it in, althought it's def more quiet. should i still download speedfan for cpu temp even though i can get the temp in bios?
