first off using water is a badd idea you use a liquid called mct-40 and with a liquid like that you nev er have to change it because it has a antifoaming and anti algae growth so you really dont have to change it if it is in closed and there is no dirt getting into the liquitthow often to you have to clean the water if you have a liquid cooled system
Originally posted by: mindwreck
generally recommended every half year, just as a precaution to make sure the coolant is fine. You can leave it in longer, probably wouldn't matter much.
If you have a complete single metal system (ie. all copper components) then distalled water is all you need. If you have mixed metals, you will need distilled water and some anti corrosive additive to further slow down the corrosion process.
the anti-corrosize stuff also helps in keeping the crawly things out.
