Originally posted by: aigomorla
Originally posted by: TheStu
i thinkn you are missing part of my point... the first point was that i didnt want the big green tubes and you have certainly addressed that, however i also mention that i am curious if there would be a significant problem with using straights and 90 degree turns instead of just tubes going from A to B. It would be more routed and seem more like there was actual effort, planning and consideration put into it.
water flow will always be restricted at 90 degree's. The most common and somewhat fatal mistake in water cooling is when the tube kinks and the water is cut off. That is why there are kink gaurds to prevent the tube from bending a full 90.
I would have to say depending on the pump your using and how many 90 degree elbow joints, u should be fine. The more 90 degree elbows u use, the stronger pump your going to need.
Also, as wiz said, the water coming out of the block isnt very hot because if u concider the fact that water is being pushed at nearly 75gph, on decient pumps, the water doesnt stay on the block long enough for it to heat up drastically. Yet since u got water being pushed though consistantly, the block is cooled. However, i did read when ur doing a SLI cooling on a WC, u should use Y spliters.
Just a little advice, if ur really anal and want maximum cooling, u could always use a Y spliter. It would be something like this.
3 port Res. (outlet) -> radiator -> pump -> Y split one going to CPU the other going to GPU -> then have both exit to each inlet on your 3 port res.
Since some bay res's have 2 inlet ports and 1 outlet port, u could pull it off that way.
I hope this helps :]
