edit: if i may ask why do you want water cooling ? and if you had a good reason no way order it from newegg.
not to insult you but you really should do your research if you knew about water cooling you wouldnt order it from newgg and you would know water cooling is pretty much just for the ohhh factor if you think since you have water cooling your gonna hit this crazy clock speed and what not that depends on the chip.
Reserator sucks for cooling. You can do as well with high-end air cooling. Reserator is if you want quietness. A better newbie water cooling kit would be the Koolance Exos-2 It's $400 for cpu cooling, a little pricey, but you said cost wasnt a concern. Koolance designs effective water cooling systems for the newbie. Since you have no experience water cooling, this would be a great starter kit.
