- Mar 18, 2005
- 164
- 0
- 0
Well im putting together a water cooling kit and i decided on some tygon tubing. Its a little more expensive but from what i have read is the best stuff there is.
Im a uv blue freak so since tygon is clear i was gonna get some uv blue dye. But then i read that uv dye looses its glow and isnt very good to begin with.
What is the best dye I can get? Or should i screw the tygon and get some uv tubing.
Here are two water cooling kits i simply envy and really like for you to get an idea on what im going for
1#
http://modtown.co.uk/mt/images/article/maze3/1_small.jpg
2#
http://img234.exs.cx/my.php?loc=img234&image=67nw.png
1#
2#
