I am going to purchase a water cooling kit soon with a 120mm fan compatible radiator. I have a lian-li PC65 case that only allows 80mm fans for the top and rear blowholes.
What is an efficient solution to fit a 120mm radiator over a 80mm fan hole? (I want to stay away from drilling a bigger hole) Is there any fan adapters for 80mm>120mm? Would the noise and airflow with such devices be altered?
Thanks
Thanks
