Water Cooling that fits inside the Antec Super Lan Boy
I have been having a hard time to find a water cooling kit that will fit inside my Antec Super lan Boy, because i am using MSI K8N Diamond with SLi...the top slot os used and there is not much left for the RAD as there is only 1 inches between my Top PCI=E Video card and the 120mm fan at the back on my case now. Any other kits that may fit?
P.S. prefer not to have the RAD outside as I carry the system in and out 2 times a week to other places...
i've seen people attach the rad outside to the back where the case fan hole is. would that be viable? i dunno how else you'd do it in there, it's a really tight fit.
it should still be pretty portable. maybe cut the grill out of the back for better air flow, put a fan on the inside. just brainstorming.
yeah you can probably mount the rad outside on the back where the fan hole is. Ive seen people use an old 120mm fan frame to hold it to the case, and give it space for airflow. That would be pretty sturdy I think. You would need to drill some holes in the metal on the back for the tubes to go through, but thats simple. All the rest of the components should fit in nicely. I think with that cramped a case, its probably best out mount it outside somewhere. Maybe even an exterior top mount? Hmm...
