Hi all,
Some help please. I have an AMD X2 4800+ with a Thermaltake Bigwater water cooling system installed. I used AS5 on the chip, and lapped it a bit.
Over the last week or so, I have been noticing that my CPU temperatures are creeping up slightly. I have actually had to reduce the overclock slightly to prevent the machine hanging. Funny thing is that Winter is on its way here, and the ambient temperatures are dropping, yet I am still having the high CPU temperature problems.
The water cooling system comes default with 3 fans on the radiators (1 single and 1 double). I added another 3 fans to this. I also used antifeeze to make up for what was needed with the original antifreeze that came with the kit.
The pump has been replaced as the original one failed after a few months.
Any ideas on where to look for a problem? Pump not pumping properly, antifreeze need thining out?
Any help will be appreciated.
