Would water cooling be more effective in a situation with higher ambient temps, versus air? If the ambient temp was say 100+ degrees, and you were trying to cool lower end P4s (say like 1.4GHz P4s), would air be as effective, or less effective than a water cooling setup? This wouldn't be for OCing or anything--just keeping the processors / machines operational.
Also, from what I can see, it seems most WC setups have it setup as follows: blocks -> resevoir -> pump -> radioator -> back to blocks.
If you were using multiple blocks to cool ~4 - 6 processors, could you daisy chain the blocks, or would other modification to the cooling flow be required? Such as adding another pump & resevoir or pump & radiator inbetween?
