1)im looking for a pump and im at marinedepot.com which section do i check? external or air pumps? since im going for cheap and value whats a decent head and gallon rating? i want inlet not sub.
2) so what happens when i turn off my computer? do i need to turn off the pump also? and vise versa.
if so this is kinda tricky becuase if i forget to turn the pump back on then im hurting the cpu correct?any way for auto turn on like the WC kits?
3) how does the water block mount really? like if i were to buy a used one how would i know what bolts and what nots to buy?
thats all i have for now thanks
