Water cooling question
h2sammmo
22
i just got my water cooling kit from the DangerDen.
my question is.
do i need to worry about condensation even if i dont install a peltier?
will condenstaion be a problem with H2O cooling alone?
thx for input
:D
2Cool
649
Nope, so long as you are at or above room temperature you have no worries about condensation. Leaks are a worry though... make sure your connections are all clamped and secure, and test the system while you have it open and make sure its tight.
