- Mar 26, 2001
- 431
- 0
- 71
I just got from a chubby wallet deal and installed a koolance PC2-601BW .
I am getting liquid coolant temp of 23 c 75 f from the lcd on top of my case and nivdia system utility is telling me that my cpu is 44 c and system 24 c.
According to koolance
Actual system temperatures can vary based on many factors. In general, your CPU die temperature will be 10-20oC (18-36oF) above the Koolance LED display (coolant temperature), depending on the processor type. The liquid coolant will be 4-14oC (7.2-25.2oF) above ambient, depending on power duration, system stress, and the Koolance cooling "mode" selection."
Did I do something wrong on install? I have a wateriing cooling block on the cpu. I did not trim the tubing the came prehooked up, it didnt seem excessively long.
Also am i suppose to take off the plastic guard that is attached under the radiator? its clear.
I got the system because the noise was driving me nuts from my aero flow so that temps are ok for me, just wondering if i am doing something wrong or is this typical of a cheap water cooling system like Koolance
thanks
thanks
