ok im looking into water cooling my rig amd skt 939 3200 and vid card nvidia 7800 gt im looking at running a combo of setups first off i have an antech p180 case, im looking at getting a Thermaltake Big Water SE then going out of that to the cpu then vga, then out of the case to a Thermaltake CL-W0042 setup which is an external water cooling system radiator and pump assembly, then into a Thermaltake AquaBay CL-W0032 Cooling System 2U Liquid Level & Flow Indicator which will be in the top two bays of my case, the thought is that the first radiator... thoughts concerns sugestions, i havent water cooled a system sence about 2000 which i used peltier elements to chill the water before it even went to the components... my idea is to cool the water as much as possiable (obviously) before it goes back to the cpu
