water cooling p4p800
skylord23
79
im looking for a water block that is compatible with the p4p800 deluxe motherboard and also a reservoir and good fan for that. if anyone has some links that could help me out it would be helpful. would also possibly like to do the northbridge so links to a block for that would be nice. if anyone has had some experience with a setup like this let me know what you have used and your results. i do OC and im looking to take it up a notch, and im also looking to eliminate some of the other fans in my computer to lower noise.
x471x
44
http://www.frozencpu.com/ex-wat-62.html
I have the exact same board you have and this IMO is the best watercooler on the market right now. It's a little on the expensive side but the cooling performance is unmatched. You might have to do a bit of case modding tho to make it fit since the radiator is built to house 2x 120mm fans.
HardWarrior
4,400
23
This is the current champion of water-blocks. This is also a good option on the performance side, it's easier to maintain and cheaper. Both are universal mount so you don't have to worry about whether it will fit your mb. The G-cooler may look like a viable option based on cost, but the water-cooling market is full of cheap kits that simply don't measure up for one reason or another.
If cost is a major factor, I would suggest saving up and then buying better components later. You could always take this time to better familiarize yourself with the ins-and-outs of water and plan a workable strategy in regards to mounting your cooler.
NotquiteanooB
362
Have you checked out the reports on the Corsair CWC100-1000 or CWC100-1001?
Full kit; similar to the Swiftech; but some improvements. I plan to build another P5P800 system and will use the CWC100-1001 system for cooling. I liked the techie reports I saw and it looks like it would be an easy install for a newb.
