MDE
I'm considering a watercooling setup for my PC for noise and extra cooling. I've got a few questions:
1) What would be a good, quiet, powerful pump? (Eheim?)
2) What would be a good waterblock for my CPU, GPU, NB? Would I be able to transfer the NB and GPU blocks to an A64 system later on? I know of DangerDen's reputation, but I'm open to any suggestions or personal testimonials.
3) What hosing size should I use? (I'm thinking 1\2")
4) What radiator? I could pick up a car heater core if it's cheaper and the tubing will fit properly.
5) Clamp the hoses or not? What to clamp them with?
6) Reservoir suggestions- internal or external? Fitting an internal in my current case would be a problem, could I just run the tubing outside of the case? I'd be getting a bigger case for my next system (Antec P160 probably).
Here's my current system:
Athlon XP 2500+ @ 2.2GHz
Abit NF7-S 2.0
2x512MB Kingston HyperX PC4000 (both were $99 apiece, couldn't turn it down)
BFG GeForceFX 5900 (would I need to add RAMsinks to it if I watercool it?)
Audigy2 ZS Platinum
ATI TV Wonder VE
PCI 802.11b card
Antec Sonata (all 5 1\4" bays filled, one rear slot open)
I'd like to keep it under $150-200
Thanks!
Abit NF7-S 2.0
Audigy2 ZS Platinum
ATI TV Wonder VE
PCI 802.11b card
Thanks!
