Well hello every one. I'm puting my list of what I plain on purchasing here and would like some input from the more experanced personal (you). Below is what I have dug up and think i would be good with. Budget is no more then $200 hoping for $175 or even $150(don't worry I know this won't happen). Most of my system specs are in my sig and links to pictures of my comptuer are on the bottom. Thanks for all your help. Also I'm getting a gift cert for newegg so if you can find the items there that would be great if not no problem.
Reservoir
Pump
Radiator
I only have room for a 120mm or 80mm not a dual 120mm etc... 🙁
Water block
This will at least let you know what kind of room i have.
Case Pic1
Case Pic2
Case Pic3
Case Pic4
Reservoir
Pump
Radiator
Water block
Case Pic1
Case Pic2
Case Pic3
Case Pic4
