coolroyboy2
"innovaProtect corrosion protection and heat conductor" Link to product ,
Do any of you use this ? I have just set up a budget system and I'm in the process of leak testing. I have filled the system with distilled water and I would like to find an additive to prevent scum and decay of the metals I used .
I have a alum rad and a copper water block. The rad seems to be coated but I have read mixing some metals speed up their decay. This stuff says:
"Protects the water cooling system dependably against corrosion and is recommended when using a cooling system composed of different metals"
Is this worth the price or is there some other liquid that I should be using ?
