water cooling is two better than one?
BigMoe
476
sorry if this has been asked before. are two raidators better than one. will there be any seeable diffrance? why do some people use bigger one {car, snowmobile}?
s2kpacifist
108
Unless you're outputting some serious heat, 2 medium size radiators (over 80 mm) is a little overkill (and cluttered inside the case). However, if you are putting out huge amounts of heat, I think that two radiators should do the job nicely.
