As you are probably all aware, once you get all the air bubbles out of a water cooled system, the pipes will fill completely with fluid. This way, even if you have transparent pipes, you won't be able to see the water flowing through the pipes - they'll just appear a solid colour.
Is there something that can be added to the water to make the water flow visible just by looking at the pipes? Maybe something commercially available for this purpose?
If not, then what could safely be added for this purpose? One low-tech idea may be to use glitter or some other small solid particles in suspension, but I'd like to hear some ideas for chemicals that can be mixed into the water that make flow lines visible. I think concentrated automotive antifreeze changes colour slightly where it flows, so maybe areas of turbulence would be visible if this is used?
Another idea is maybe to add to the water a chemical that changes colour with temperature (same stuff they use for sticker thermometers) - that way maybe you can see some nice thermal profiles of the flow inside the water block if they have clear covers.
P.S. If you're wondering what the point of this would be, well, two somewhat good reasons:
1. Most water-cooled setups have windowed cases and transparent pipes. If you can visualise the flow you'd be able to tell at a glance if the pump has failed or some other flow problem has occured
2. I for one think it'd be cool to see the water going around in the cooling loop every time I look into the case
