I have a question which I intend to use in starting another thread. But I saw this, and thought I would add two cents worth.
Given my connection to microcomputers going back to 1982, I should have built a water-cooled system by now. Every time I go to the Pomona Computer Fair, I find myself looking wistfully at the Reserator demostration setups, the Swiftech radiators, the array of components and clear plastic tubing.
My friend across town and I built our latest (last) generation socket-478 pentium 4's during the last six months or so, and it became something of a competition. The friend has also been a "Jeeper" in his life, he has two jeeps with the engines all rigged out in chrome . . . an inveterate do-it-yourselfer.
Around June, I visited his house and discovered that he had accumulated what he described as $135 dollars worth of 4"-diameter PVC tubing and fittings to build a "Reserator"-type reservoir, the water blocks, a used auto-transmission radiator fitted to a plywood frame with two 120mm fans affixed to it, a water pump, and so on. He said "When you 'kick-my-azz' over-clocking your air-cooled system, that's when I'm going to set this baby up." But it is unclear who kicked who's . . . I'm satisfied with my 3.0C OC'd to 3.8 on air-cooling. And so, he never installed his home-made water-cooling rig -- not yet.
Instead, I spent the summer buying and testing fans. I KNOW I've spent as much on fans, many now packed into my hall-closet, as I would've spent on a Koolance EXOS system. But I know my air-cooling options, and I've taken it about as far as it goes. Except that I should probably rent a small mall-shop somewhere to set up a "fan-store".
My problem with water-cooling, despite all the manufacturers' assertions and even encouragement from Tom's Hardware Guide, involves the ever-so-miniscule threat to your system if you spring a leak, but also what seems like an extreme if your water-cooling rig isn't self-contained in the computer case -- umbilical water hoses, external reservoirs, the whole enchilada. Unless you go with phase-change or one of those more extreme refrigerative options, the only thing water buys you is cooling to a limit of room-temperature. Unless, of course, you do what some other over-clocker did, which was to bury his reservoir outside the house about six-feet under and run the hoses indoors. His water temperature is a constant 55F. Or another guy, who got a used water-cooler (the kind used in offices where people stand around and gossip about computers), to provide "refrigerated" water-cooling to his system. But then again, there you have the complication of condensation and the need to mitigate condensation and the same threat posed by leaks from a basic water-cooling system.
With the proper air-cooling, you might be able to approach room-temperature with only a 7 to 10F difference between room and idle CPU values. And with the right heatsink-heatpipe-fan combination, you might be able to clamp your load temperatures to within 14F of the idle CPU value. With water, maybe you can halve those differences -- maybe you can almost eliminate them, but they shouldn't be critical to your over-clocking effort.
True. No noise; no dust. But count on checking your case from time to time for leaks, and generally, maintenance to replace using compressed air for cleaning out dust-bunnies. And of course, if you want to move your computer, you have to unplug the reservoir.
I still may do it -- maybe next year. But "simple is best", and water-cooling just adds additional complexity to your system. If a good fan for a ThermalRight XP120 costs $14, and you can have the XP120 for as little as $48 -- with options like the Zalman CNPS-7700-Cu, the Gigabyte Ultra Rocket and some other models -- you can save more than just money in time and trouble.
I can focus my quest on simplicity to simply finding ways to reduce the number of fans while getting the same air-cooling efficiency.
