water cooling in cpu
Pelu
1,208
sup all i got a thermaltake liquid cooling kit for processor and i notice that the bubbles around are getting kinda stuck between liquid flow and gravity any idea of what to do , besides emptying the whole thing and start again lol...
Nov 26, 2005
15,197
403
bubbles stuck between liquid flow and gravity :confused:
Pelu
1,208
lol the system comes with the pieces... you even have to cut the pipes in the right length...
OCGuy
27,224
37
Just reverse the polarity.
mhouck
401
You might want to take this to the cases and cooling forum. There are experience WC'ers there.
Just a thought:
You could take the loop out of you case and tilt the block until you get the bubbles to move through the block. Hopefully that gets the liquid flowing they don't collect in the block again. I had to a similar situation w/ a reservoir about 3 months back and that's what I had to do to get a bubble out of the way of one of my ports. No problems since.
GL
daw123
2,593
Its not a pre-sealed system like the Corsair H50 since you had to cut the tubing to the correct lengths.
Are you talking about a trapped air bubble? Have you bleed the system (presumably not since you got air bubbles)? Have a look in the instruction manual for bleeding.
Oh and it would be useful if you stated which kit it is that you are using.
masteryoda34
1,399
If you have air caught in the system, you might just have to run it out. Might take an hour or two. Make sure your pump isnt cavatating though.
Sometimes tilting the case back and forth can help.
faxon
2,109
friends dont let friends use bigwater.
with that said, empty the entire system, fill it with 90% distilled water and 10% of that coolant crap they gave you, unless you have some silver nitrate powder lying around. this should prevent algae from growing in it and distilled water cools just as well as that coolant will. bleed the system before closing it up if you can (preferably through the res since i doubt you have a T line), and the bubbles should be gone.
Pelu
1,208
lol... is a big water one... is a thermaltake, bigwater 760is... and yeah those bubbles are troubling me... so far I manage to get rid of tons of those... a few littles ones are stuck there... playing with the tubing around helps and hitting the tube with a pencil lol...
Is kinda cool watching them move around the pipes... but when one of them get stuck in a really meanny position that i cant move the pipe because is close to the procesor waterblock or the radiator.. i get annoyed...
Pelu
1,208
the way i did mine was i tilted it any which way it needed... damn case was heavy after a while...
computer on or off?
aigomorla
21,134
3,671
:X
my best advice is go on air... dont try to fix it... remove it.
You'll thank me in the long run later.
The bigwater kits are very bad. Horrible to be honest. There prone to pump failures and other problems.
Nov 26, 2005
15,197
403
Originally posted by: aigomorla
:X
+1
Pelu
1,208
anyway whats better.. shorter pipes... only the minimun needed length or long ones... ?
Beanie46
527
lol... are water stuff really that bad...?
No, watercooling "stuff" is not bad, just Thermaltake watercooling is junk, pure and simple.
Best advice, you can buy a prebuilt kit, something like this from Petra's:
http://www.petrastechshop.com/pecoba.html
OR.....you can piece together a kit......common recommendations include:
Swiftech radiators....best bang for buck radiators on the market
Pumps....DDC or D5, both produced by Laing, sold by Swiftech (MCP350/355 or MCP 655 series) and Danger Den, among others
CPU block....lot of choices, some more popular ones lately are Swiftech's GTZ, Watercool HK 3.0, Enzotech Sapphire Rev. 2, amongst others
Tubing....current favorite is Primochill LRT, size is up to you
Popular sites for watercooling parts: (First three are excellent choices and all have excellent customer service!)
http://www.sidewindercomputers.com/
http://www.jab-tech.com/
http://www.performance-pcs.com...ex.php?main_page=index (Tons of stuff, BUT....very expensive place!)
RavenGuard
134
You really have to use a few more grammar skills, it looks like I'm not the only one who has no idea what you're talking about.
