Hi. I'm looking to take the plunge into alternative cooling and right now I'm leaning towards water cooling. My main motivation is noise: For the past 4 or 5 years, have a 120mm fan hacked onto my main box. I've swapped fans a few times and have settled on a Panaflow rated at 39db and I've finally decided that even 39db is too loud.
How much noise does a decent water-cooling/radiator setup make? I've seen radiators with multiple 92mm fans or a 120mm fan. Now, as far fans go, my Panaflow is one of the quieter 120mm fans available so it seems to me that if I go with a 120mm radiator setup, I won't gain much in terms of quiet.
Do people normally attach PWM speed controllers to their radiator fans?
