Water cooling help
Pillowite
18
I'm in need of a new case and I'm having problems picking out one that would work.
My wants:
Gromits for cable management
Full tower
Removable hdd cages
Tons of air flow
Big cpu cutout (current case, haf 922, doesn't have it big enough
Separate compartment at bottom for psu and radiator
Full glass side panel to show off insides
I've looked at the corsair 900d, but that's pretty expensive. Something like that but cheaper. $200 budget
Specs:
Asus p8z77-v pro
Gigabyte hd 7970 ghz 3gb
Radeon hd 7450 (runs 2nd monitor...yes it's possible)
8gb 1600 mhz
i5 2500k (corsair h80I) @4.325 ghz
Corsair tx850 v2
x2 1tb hdd
krnmastersgt
2,873
It's a bit more than $200 but the Phanteks Enthoo Primo is very highly regarded, almost as large as the 900D, and has pretty much everything you listed along with huge WC mounting support.
That being said your current rig doesn't seem it needs a case of this caliber in terms of WC, were you looking for a case the size of the 900D or something smaller? The Luxe and Pro from Phanteks' Enthoo line are great options for half the price.
_UP_
144
11
I'll second the Phanteks. Just got it a week ago and it's quite amazing. It's huge and has lots of rad space (2x 480 plus 240).
Also comes in white :)
