Hi,
Ive been considering moving to a water cooling set up from my current one.
I have a couple of questions though.
1) Is it really worth it?
2) Is water cooling that much quieter than air cooling(more specifically a system with 6 20dBa fans)
3) A kit that ive seen(see below)seems good, but where would i mount the pump/res and the rad? Would they be loose in the case, or do they come with a way to secure them to the case?
4) Would i be better going for something like a Koolance EXOS, and are they any good?
Heres the system that i`ve seen.
WaterChill KT03-L20 CPU Cooling Kit w/VGA Cooler Block w/North Bridge Cooler Block.
Link
Also, do any of you know anywhere in the UK that sells the new Corsair Hydrocool 200 external water cooler? Cos that seems significantly better than the Koolance.
Thanks in advance guys/gals.
Link
