Water cooling for under $100?
WinkOsmosis
Banned
Sep 18, 2002
13,990
My friend wants to buy a watercooling system for her boyfriend and she asked me about it, but I don't know anything about water cooling anymore. Is it possible to do it for under $100?
tooltime
1,029
i know nothing about water cooling except it makes me squeemish thinking i'd screw it up
Godfather04
395
thats gonna be tough to do if you want it custom,but if you just want a cheap kit you can buy an Aquarius II WC kit for around $100 but it is all that great of a kit,you can run into leaks and stuff but it's up to you.
bootoo
671
check out aquastealth.com I believe it is; they have a kit I was pointed to buy an amd'er who has 2 and really likes them. They're more upgradable.
After xmas shopping madness subsides (and my credit card bounces back) I'm going to snag one - with the reservoir upgrade - he says they're reliable and you can use them for o/clocking, not just a quiet case. I've never really tried overclocking but a few folks at amd like them and as I say I like the fact you can upgrade them.
Advice from a fellow cooling noob is no help I know but check them and ask around at amd. Or here:D
klah
7,070
If you want to DIY you can get:
Danner Mag3 (350GPH): $35
Maze3 cpu block (1/2"ID): $40
1984 Chevette Heater Core: $17 (Autozone)
1/2"ID vinyl tubing: $0.21/ft (home depot)
Tubing Clamps: $2
Distilled Water:$1 (wal-mart)
Reservoirs are not needed, but do make bleeding easier than with a t-line.
Although if you are buying for someone else it is probably better to go with a kit as you do not want your gift to turn into a huge hassle for them.
Godfather04
395
Tubing Clamps: $2
Thats a good start^^^^
Goatsan
123
i dont think you will find a good watercooling system under $100 unless you make it yourself. else air cooling would still be better there.
