So ATI finallly released the video card that I've been waiting for, so I droped the $$$ to get it...but the Danger Den Maze 4 VGA block I already have doesn't fit on it. :|
Does anyone know of any VGA water blocks that will fit on the ATI All-In-Wonder X800XT video card?
Sorry bud, I can't find anything for the AIW. DD says their newest block isn't compatible with the AIW "at this time", so there's a bit of hope there. You might take the time to email them and inquire. It may help if they know there's some interest.
I took your advise and sent DD an email. They responded and said that the reason that none of the other A-I-W cards will work with any of their blocks is because of the gigantic Phillips TV tuner box...but with the AIW X800XT, the TV tuner is less than half the size, so DD said:
"We believe that our Maze4 GPUs will fit this newer video card. (A-I-W X800XT)"
So I guees I'll be getting that MAZE4 GPU block of theirs...if it doesn't fit, I guess I can try and RMA it back. 😕
