I am considering water cooling once I put my new P4 system together. I was hoping on reaching the 3 GHz mark with a Northwood 2.0 (150 MHz FSB) on an Asus P4T-E (has the 2/4 AGP/PCI dividers and the 3x memory multiplier). The thing I'm most baffled about is water cooling. Now I would like to avoid paying $200 for a kit and would like to build one myself. I can do some welding and turn the stock P4 chipset into one big water block, and attach some hoses (that usually comes with a water cooling kit but can be bought separately) to it. My concerns are:
1. What about condensations? If water inside is cold and the temperature outside the block is hot, wouldn't that mean fog will begin to leak through? Is there any way to avoid this?
2. The radiator. I currently have a Coolermaster ATC-201 and would like to avoid cutting holes in it if possible, is there any way I could passively cool the water from inside my case?
3. If it turns out I have to use a radiator, how loud would it be?
4. How much power would a pump and a radiator suck up?
5. How do I prevent condensation around the water resevour? I heard that was the easiest way to go for water cooling.
Thanks in advance!
Thanks in advance!
