Water Cooling Case Recommendations
semlethe3rd
74
Im looking for a case that can with no / very little modding hold a 3x120 rad box. So far i've found the Coolermaster HAF 932 to already have the screw holes for the radiator to be mounted internally on top which is something im liking. Does anyone else have any other cases that are as watercooling friendly as this? All suggestions are appreciated, thank you!
Nov 26, 2005
15,188
401
I thought the same thing when i first wanted to h20 cool... i'd rather cut my case and do something creative with it if it needs it than rack my brain or wallet to find something to suit lazyness..
semlethe3rd
74
I was just looking for ideas and seeing my options. I probably wont actually be getting one but well see. Any ideas / recommendations are appreciated.
semlethe3rd
74
BTRY B 529th FA BN since you have yet to recommend anything can you please stop posting? Im not asking for your feelings are or what you would do. Im asking what case you would pick if you were building a water cooling rig. For your information i've looked all over the place and am still looking, but i just wanted to see if there is something i may have over looked. Thank you for your time but please stop with the unproductive posts.
Piano Man thank you for much =)
daw123
2,593
Whichever case you choose, make sure that it is big (and definitely a full tower).
It is surprising how much space water cooling takes up.
Personally, I like my Lian li A70A, but I think its slightly outside of your budget since you would either have to mod the standard top panel or buy the optional top panel for the 3x120mm rad / fans.
Edit: Spelling
Nov 26, 2005
15,188
401
Mr. semlether3rd. You ask for recommendations then say: "I probably won't get one anyways..." Could you please explain this. Some how I feel I am being called unproductive from the one who isn't being straight forward and wastes others time. :thumbsdown:
p.s. and if you looked all over the place, you most of found this. :gift:
aigomorla
21,026
3,497
semlethe3rd
74
BTRY B 529th FA BN I dont think its a waste of time to look at an option that you may not be leaning towards but would like to at least consider. My real reason for looking at cases is my friends case has no airflow(parts are overheating due to it) and i wouldn't mind giving him my antec 900 because he doesnt have the money to spare for a case. Im not trying to insult you in any way, and i dont want this post going way off tangent. And yes I have seen mountain mods but as aigomorla said they are to expensive for what i want, thank you for the recommendation though.
Aigomorla i have looked through a ton of pictures of other peoples water cooling setups but somehow i didnt see the subsection in xtremesystems for their worklogs =). Your going to keep me busy for days thanks :p.
PCTC2 I have looked at this case before and thought about it for awhile. Do you think it is better than the CM HAF 932?
cdnbum88
399
Have you considered the Cosmos S?
I have a triple up top and a double in the drive bay.
