I'm trying to cool down the ambient air temps in my room where I'm running my gaming pc and a server. The gamer's a 3500+ running at 2.662 mhz with a Thermalright XP-90, a Seasonic S12 PWS and BFG 6800GT with an Artic Cooler. They're housed in an Antec SLK 3000 with Nexus 120's all around. It's a great quiet rig but it can get toasty. Short of getting a portable AC unit to chill the air at the case outputs, I thought I'd try water.
I haven't had any performance issues and the cpu temps are fine but it puts out a lot of heat so I'm wondering if converting over to a water cooling setup for the cpu and video card would lower lower the internal case temps and therefore the output case temps.
I realize that the heat would still be dissipated through the cooling condenser but I was thinking the output air temps from the condenser would be lower than the air temps of the current setup, and of course there is the noise issue of the pump. I also realize that the PWS is probably the biggest output heat source, but I have to start somewhere.
