Originally Posted by MaxxxRacer
Fact 1:
Ethylene Glycol and Propylene Glycol, are considered to be non toxic when consumed in small to medium dosages, while large amounts can result in nausea, convulsions, slurred speech, disorientation, and heart and kidney problems. VERY large dosages can result in renal failure and death, but such high dosages would only be incurred by intention ingestion of ridiculous amounts of it, such as drinking a gallon of Anti-Freeze. It should be taken into consideration that Ethylene Glycol is suspected to be more poisinous than propylene glycol, but there is no official statement on this. EPA Article on Ethylene Glycol
Fact 2:
Polyethylene Glycol, Polypropylene Glycol, Ethylene Glycol and Propylene Glycol, are considered for most purpose to be essentially the same thing, and who?s chemical properties are nearly identical, as well has having identical effects on humans and cooling systems. In short, Zerex saying it uses Ethylene Glycol instead of Polypropylene glycol really doesn?t matter. They are essentially one in the same.
Fact 3:
The aforementioned Glycols are covalent compounds, with some ionic properties, and when dissolved in water form slightly acidic solutions which conduct electricity (they are weak electrolytes), and in turn promote galvanic corrosion. Radiator fluid manufacturers add certain chemicals to counteract the electrolytic effect of the Glycols, thus stopping galvanic corrosion from occurring, but by themselves will cause corrosion.
Fact 4:
Glycols ONLY purpose in cooling systems is to increase waters boiling point and reduce its freezing point, with the lowest freezing point for Glycols being around -45C where the Glycol has a molar mass 430g/mol.
Fact 5:
Copper, copper sulfate, endothall, simazine, and diquat dibromide are all different active ingredients used Algaecides (products that kill Algae). You will notice that Copper is on the top of that list. That?s right folks. The main cooling component of your watercooling loop will kill most algae all by its lonesome. Some algae are immune to copper, and can be identified by their blue-green color. Also, diquat dibormide is essentially a stable liquid (in aqueous solution) form of bromine gas, which is used to kill various bacteria.
Fact 6:
If you are looking to gain a bit more performance out of your water, nonionic surfactants are the way to go. (Froogle: ?nonionic surfactant? to purchase). Choose nonionic because they will not increase the conductivity of your coolant like ionic surfactants will, thus keeping your electronics as safe as possible in the unlikely case of a spill. Common nonionic surfactants include: alkyl polyglycosides, Alkyl ether sulfate, Amine oxide, and Linear alkylate sulfonate
Conclusion:
In a properly setup PC cooling system which contains no mixed metals, and uses copper/brass as the metal of choice, no coolant additives are required. Pure deionized water or distilled water will be your best choice, with a small amount of nonionic surfactant added for that extra .01C if your interested.
