hi all. First post 🙂
Anyway, I have purchased the following and have looked aorund the net for the best routing of it and wanted your opinions and advice.
DangerDen TDX for A64
DangerDen SLI cooling solution
Asetek 3.5" HDD cooler
Swiftech MCRES1000 /w MCP-350 pump
DangerDen Black Ice Extreme 2 radiator using 2 120mm Vantec stealths
What is the best component order routing for this set up?
Also where can I get a dual 120mm fan shroud for the Black Ice radiator?
Thanks all in advance for the help!
XipeTotec
XipeTotec
