- Jun 23, 2003
- 2
- 0
- 0
I own a Antec SX800II with a water cooling kit that I installed. The problem is that when I try to install the radiator to the back it doesn't fit since normally the 80mm fans would go into the brackets (The thing that holds the fan). I tried take them out but it is doesnt have any screw holes to install the radiator to. Same goes for the front of the case. How do I attach it to my case? If not by the way I want it, tell me another way to do it or tell me what radiator I should buy that would be capable since I am planning to buy a new and better one. Post a message, thanks.
