I'm going for a dual AMD system, and am planning on water cooling it. My current dilemma is how to hook up the tubing to get the best cooling effectiveness for the system. Hooking them up serially will definately affect the flow rate and reduce the amount the 2nd processor gets cooled.
I've been thinking of hooking them up in parallel, but that would also cut the flow rate in half. My current winning idea is to use 1/2" tubing as the main tubing, then run 3/8" tubing to each processor in parallel. The thinking here is to keep the flow rate a little higher in the processor block, but it wouldn't be completely 1/2 of the original flow rate.
Any thoughts or comments on this?
Thanks.
Thanks.
